Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Points in sketch do not show up in DXF file
kerry7TP8V
kerry7TP8V
I have 16 points and 4 lines in a very simple sketch. When I right click on the sketch and choose the Save As DXF option, the points are not included in the DXF file. These points are independent of the lines. How do I get the points to save to the DXF. The points are used by my Plasma Cutter software (Sheetcam).
LeonardoBN
Hi @kerry7TP8V.
Save as DXF seems not be able to keep points.
I was able to save a DXF with points in File/Export/DXF. This requires cloud translation, so you will have to wait a little to get your file.
The attached file was created in this way.
Captura de tela 2020-09-18 19.44.38.pngCaptura de tela 2020-09-18 19.44.38.png
Image of an imported DXF (created by Export/DXF).
Leonardo Brunelli do Nascimento
Chemical Engineer
kerry7TP8V
Using file export to create a DXF results in the wrong scale in my CAM program. That's why I have to use the sketch/save as dxf.
g-andresen
Maybe small circles work (e.g. 0.01mm).
Günther
madscientist9898
Community Visitor
Community Visitor
Ran into the exact same problem. Now in order to export as a DXF you have to have a paid subscription. I find it great how fusion suckered everyone into learning and using their program by marketing it all over YouTube giving full access to the program. Now here they are slowly removing features bit by bit for us hobbyist.
