Pointer highlight
mac_ito
Pointer highlight
mac_ito
Will it be possible in the near future to have the possibility of deactivating the highlighting of the pointer. I mean, disable the fact that the element hovered over by the mouse pointer changes appearance. On a daily basis it is terribly tiring for me to see my assemblies flashing like Christmas trees. The ideal would be to be able to select what you want to shine, (body, component, skecth). If such a development is not possible at least allow to be able to regulate the level of brilliance.
thx
Replies (12)
sutherland-
Hi @mac_ito
For your information, below are about how to modify the environment XML file to "turn off" face selection highlight.
1. Find the related environment XML file, such as PhotoBooth.xml (or DarkSky, GreyRoom, etc.)
  • find the Fusion360.exe location (from taskmanager) if use windows OS
  • find XML file such as PhotoBooth.xml in "Neutron\Server\Scene\Resources\Environments\PhotoBooth\PhotoBooth.xml"
  • Example:  C:\Users\zhanglo\AppData\Local\Autodesk\webdeploy\production\9dc57ac7328faaa98e6bb4734628b2fbd5d10ece\Neutron\Server\Scene\Resources\Environments\PhotoBooth\PhotoBooth.xml
2. Modify the XML file, Use Background colour for HighlightEffectInfo colours, then restart Fusion 360. You could backup the original XML file first.
Use this at your own risk!
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
mac_ito
Hi thank you for this tips. I already knew it but not so well detailed unfortunately this possibility is not possible on macOS. It seems that on macOS the xml files are not accessible
mac_ito
@sutherland-Do you confirm this? or can you give the access path on macos?
sutherland-
I do not have MacOS, therefore I cannot confirm or deny. It is out of my hands here.
Best regards,
Level  sutherland-
Member
mac_ito
Too bad, can you ask someone using macos?
Nevertheless I would mention your previous message as a solution because it has the merit of bringing help to Windows users
sutherland-
I am just a community member trying to solve issues, I am not an Autodesk employee. 🙂
Best regards,
Level  sutherland-
Member
mac_ito
A solution for macOS would be welcome
@TrippyLighting half validated
mac_ito
Is there a macOS specialist on the forum who can give me the name and path to access these files? Thx
mac_ito
and we talk about this problem @Phil.E   , that’s my daily life..
mac_ito
On macos, I was able to get the path to the .xml files so I was able to try to modify values ​​and I managed to remove the highlight effect when the pointer passes over a face.
  1. Right click on the dock icon, show in finder
  2. Right click on the Fusion application icon, show contents.
  3. Contents/Libraries/Neutron/Neutron/Server/Scene/Resources
the full path : /Users/xxx/Library/Application Support/Autodesk/webdeploy/production/xx most recent file xx/Autodesk Fusion 360.app/Contents/Libraries/Neutron/Neutron/Server/Scene/Resources
To do this you have to enter the following value like this <HighlightEffectInfo BaseColorRGBA="0 0 0 0"
Be careful this also has the effect of not displaying a highlight when selecting a hidden element with a long press
@sutherland- If you tell me what these labels correspond to?
mac_ito
@sutherland- it's ok I got it
mac_ito
There is just one color that I can't change, it's the one when you select directly from the browser or by double-clicking, any idea of ​​the label to change?
