point to point move of round component
Message 1 of 55
After new update today I can't select the center of any round face for a point to point move.  I'm trying to move a flat washer to a round hole and can't select the center of the washer or the center of the hole.  Looking for a way around it.
Replies (54)
Message 21 of 55
Beyondforce
@TrippyLighting
Even if you are using DM, you should create the components In-place or use the Joints. I would really want to see a situation, where you have to use the Move tool. I'm very curious now!
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 22 of 55
Yes for a single component or a rigid group. But I can't copy a rigid group. My issue is I snag bolt, washer and nut off of mcmaster car and want to put this in multiple places as a group so after I get the first one done I just copy the set and then paste it using the point-to-point, then re-paste and do the next. The only way to use align is to make a new component for the nut bolt washer set and then copy and align the set. Not bad just different and me off this morning.
Message 23 of 55
Yes you are totally correct but in situations like this we have to accept the reality and find a workaround until they sort the issue out, the point to point move tool is very handy and I do use it, I am sure they will fix this one quickly.
Message 24 of 55
Hi Jeff,
I've also noticed that when you import a new object or file into an exsiting one, switching between point to point and free move resets any object rotation before the move is completed.
Thanks for looking into this problem!
Best,
Monty
Message 25 of 55
Beyondforce
@Anonymous
May I ask, why aren't using the Joint command?
Ben.
Ben Korez
| YouTube
Message 26 of 55
Yes, like that and I just found out that Free Move isn't exactly like the old move where if we click on one of the directional handles, we can then select the surface we want it to move to. Now it selects that component, seriously is it so hard to people to click cmd/shift key to add more components to be moved?
I think I found a solution to this problem, if the component you wanna capture surface was grounded, then it can be captured the same as the previous version was. Troublesome, but effective. Try it.
Message 27 of 55
I prefer not to use the joint command because in many cases for me, I am moving bodies that are not necessarily a component to another. By using the joint tool, it adds a step which I have to delete the joint tab after I move the object. The original move tool just made things very simple for me - and I assume many others.
Message 28 of 55
Beyondforce
Are you familiar with R.U.L.E #1?
https://forums.autodesk.com/t5/post-your-tips-and-tutorials/fusion-360-r-u-l-e-1-and-2/td-p/6581749
Ben Korez
| YouTube
Message 29 of 55
O.Tan
But that requires the referenced component to be grounded which can cause all sorts of other issues
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Message 30 of 55
Hahaha, that's true. Although, I prefer the K.I.S.S Rule over all engineering rules.
Regardless sounds like AutoDesk is looking to fix this issue asap anyway.
Message 31 of 55
O.Tan
Yeah, I suspect AD is already well aware of the issue and will give us back our old move tool, even if it's renamed as Free Move.
Omar Tan
Malaysia
Message 32 of 55
There is a flip button on the align window that lets you change the direction to the way you want it to be.
Message 33 of 55
TrippyLighting
When you have a couple thousand hours worked with Fusion 360 you'll have discovered that yes the flip button does flip the part, but it is still is not always oriented the way you want it.
@Beyondforce When you start designing complex objects - I deliberately avoid the term "component" because that's not the topic - then designing in place is often not practical, or even possible.
Message 34 of 55
Beyondforce
@TrippyLighting
Now I have to know what "complex objects" means!?
Ben Korez
| YouTube
Message 35 of 55
gareth.j.price
I have been using f360 for 2+ years now and use the move tool and point to point all the time it is a major part of my workflow especially when you have a huge library of components that you import into your assemblies. The joint tool is a very specific tool and not a requirement for placing a nut or bolt, the same goes for the align tool it has again its own use cases but for the day to day alignment of small objects quickly the move tool is invaluable ( or was ).
Message 36 of 55
Beyondforce
If the Joint tool is not a Point to Point tool, then what is it!? I'm trying to understand, why the move tool is better for positioning parts.
Ben Korez
| YouTube
Message 37 of 55
gareth.j.price
why would i want to create a joint to place a washer over a hole?
Message 38 of 55
Same here.  I don't always need or want the function of a joint and for me the old point to point function was the fastest way I had found for getting imported parts into position.  Since this last update I have been using the align which does not seem near as quick.  It has been especially annoying when I try to move groups of components at the same time.
Message 39 of 55
Beyondforce
You just answered your own question... to Place and to Join (fix it in place so it won't move). With the Joint tool, you are making two moves in one action 😉
Ben Korez
| YouTube
Message 40 of 55
Beyondforce
@Anonymous, @gareth.j.price
Guys, don't get me wrong. I'm not trying to criticized your workflow, I'm just trying to understand your workflow and perhaps learn something new!
Ben Korez
| YouTube
