Please help with "formula" for pipe sizing with thread
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Fusion 360 2.0.10148; Personal plan
(This is my very first attempt at something like this.)
I need to print a reducing socket with thread on the inside for my vacuum cleaner I need to hook onto my planer.
Vacuum pipe OD: 48mm x 5mm
I designed a socket with an ID of 48mm with an:
ISO Metric profile
Designation: M48 x 5
Class: 6H
Direction: Left Hand
The pipe does not fit into the socket ... not even close.
So I measured the ID of the socket and it measures 42.7 mm. My guess now it that the thread is added on the inside of the socket and not cut into the wall of the socket. I made it with an OD of 53 mm which I thought was enough for the threat to be cut into the wall.
Please advise me on the "formula" to calculate ID of a socket into which a vacuum hose with in OD of 48 mm should fit.
Thanks so long.
