Please help reverse this fillet?
How can I reverse this fillet so it adds material instead of removing material?
Thank you
JamieGilchrist
hi colemanVJMPP,
you'll have to sketch the profile/shape you want and revolve it
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
HughesTooling
You might be able to use Pipe as well.
Mark
Mark Hughes
Owner, Hughes Tooling
Yes I am aware I can revolve there to get what I am looking for BUT sometimes the fillet tool works the other way.  Look at the screencast.
The fillet tool can add material there.
Sometimes it adds....sometimes it removes.  How do I select which way the fillet tool works?  It is just random for me at this point.
jeff_strater
@Anonymous,
It is not random at all.  A "concave" edge will always add material, a "convex" edge will always remove material:
Jeff
Jeff Strater
Engineering Director
@jeff_strater
1) then why did @JamieGilchrist tell me I needed to revolve?
2) check out this screencast.  This is the same document, same part that 20 minutes ago was behaving like a concave corner.
jeff_strater
@Anonymous,
When that video was recorded, your two cylinders were separate bodies, not joined together.  So, that edge that you Filleted in that video was, indeed, a convex edge on the top body.  In the earlier video, those bodies were joined into a single body, so that edge was a concave edge on the single body.  Expand the "bodies" folder, and you will see that there are two bodies in there.
Here is a screencast:
Jeff
Jeff Strater
