Please add posibility to fixed line length
jan_stuchlik
jan_stuchlik
If I know, dimension is only one way, how fix lni lengh. But in some cases
I don't care about its value.
another wayt is to add "fix length" constraint.
Thank you very much.
laughingcreek
you mean this?
jan_stuchlik
Another scenario  - I use it very often dimension with a reference to another (fx), or with some formula, but it would be nice not look like current dimension. In fact, it can be constraint (same lenght), maybe also same amngle, maybe :dimension constraint vs. visible contraint. Some variant is also possible and similar to lines - dimension in :construction mode" - so it is lighter, maybe dashed, but visible very light (only dashed is not enough).
Ok, I am creating new Fature request.
jan_stuchlik
Thank you for this reply, by line is fixed in length and in positioon. I need only fixed dimension.
TheCADWhisperer
@jan_stuchlik wrote:
... need only ... dimension.
D and then add dimension.
jan_stuchlik
No, I need only fixed length. sry duplicate
