Planetary Gears Motion
zenkustumz
Message 1 of 10
zenkustumz
can someone assist in how to apply motion to the planetary gears.
i'm not really sure where to start. I would like assistance to know how to do it and maybe a step by step on the first relation so i can
do the rest to learn how to do it.
http://a360.co/2lJ5azd
Thanks in advance
John
Replies (9)
Message 2 of 10
HughesTooling
See attached file. I added one more joint then 4 motion links. If you enable component drag you'll be able to drag the gears around.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
zenkustumz
figured out 3 joints but cant get the last one ??
Message 4 of 10
HughesTooling
Don't know if you're going to try and make this but you have a problem with the outer gear. Actually thinking about it a bit more the problem is the small gear, gears with less than about 20 teeth need undercuts to get around the problem below. There's some info here if you're interested.
Mark
Mark Hughes
Message 5 of 10
zenkustumz
kinda understand but how to i remedy this?
Message 6 of 10
HughesTooling
What do you want help with, the joint setup or the gear under cuts?
Mark
Mark Hughes
Message 7 of 10
TheCADWhisperer
How about some Fillets on the Ring Gear?
Oops, that didn't work out so well.
Looks like Fusion still has a way to go till it is ready for the classroom.
Message 8 of 10
HughesTooling
@zenkustumz First off you've made quite a mess moving bodies around instead of components, it took quite a while to fix. You should have just used Joints not the Move command for this.
Here you can see your origins are all over the place and at odd angles.
The first thing I did was move all the bodies back to their origins and reset their rotations. Then I made this screencast to show a workaround for the undercut, it's not perfect but it's works with a rack, you'll see at the end it doesn't quite work with your ring gear. In the attached file I've cut the centre of the ring gear a bit bigger so I could add fillets as @TheCADWhisperer suggested. I also added 2 more fillets to the small gear.
Mark
Edit forgot to attach the file.
Mark Hughes
Message 9 of 10
HughesTooling
Here's another screencast that shows how to make copies of the small gear and finish setting up the motion links.
Mark
Mark Hughes
Message 10 of 10
etfrench
Attached are Module 2 gears created in Gearotic, so the tooth form should have the correct form.  They are in stl form, so you can use the mesh tools to create a regular 3d model.
ETFrench
