Plane along path
Plane along path
LMD001
Message 1 of 11
Plane along path
LMD001
Hello Everybody,
When creating a Plane Along path, the preview looks OK but when created the plane rotates.
Is there a way to avoid this?
Link to ScreenCast: https://screencast.autodesk.com/main/details/bb2ef531-03f8-4104-b6c3-2d95f524be04
Thanks for looking at this.
Best Regards,
Ludo
Replies (10)
Message 2 of 11
MichaelAubry
Hey Ludo,
Not that I know of. I assume you want to keep the orientation for orthogonal dimensioning purposes?
Mike
Michael Aubry
Autodesk Fusion 360 Evangelist
Message 3 of 11
LMD001
Hello Mike,
Exactly, when I make a sketch on that plane, it is, off course, in the same orientation, making it more difficult to keep the sketch orthogonal to this path. The preview just seems more like what I expect.
Thanks for looking into this!
Best regards,
Ludo
Message 4 of 11
AnandSomani
Hi Ludo,
Thanks for reporting this.
I believe the path you are selecting is 3D. Because apparently it happens only when the path is 3D.
Also, this is only limited to Parametric environment. It will not happen in Direct modeling environment.
Nonetheless, this is indeed an issue. The preview and the result must match.
We will fix this. Sorry for the inconvenience.
Anand
(Autodesk Fusion Developer)
Message 5 of 11
LMD001
Hello Anand,
Thanks!
Best regards,
Ludo
Message 6 of 11
Has this been fixed yet?
Message 7 of 11
Nope. This issue is currently massively bugging me since the preview is orthogonally perfect but once I commit the creation of the plane, it pops to a different orientation.
Message 8 of 11
ptplopes
Hello All,
The problem I've been struggling with is the issue of the sketch rotating when executing the sweep. Has anyone seen this?
Using a sketch other than a circle (a rectangle for example) when using the sweep command the sketch rotates around the path. Very strange!
No matter how many adjustments I try, I cannot reach a result where the sketch remains unchanged.
I will try to attach an image of the results I arrived at.
Regards
Paulo de Tarso
Message 9 of 11
jhackney1972
Take a look at the video I think will solve your issue.  If it does, please do not forget to select "Accept Solution" for my post even if this Forum post already has one Accept Solution it can have another.  Ask further question, directly to me, not the original poster since you hijacked a very old post, if you need to.
(view in My Videos)
John Hackney, Retired
Message 10 of 11
ptplopes
Hi John, Thanks very much for the solution !!!
Where can I find the "Accept Solution icon"?
kind regards,
Paulo de Tarso
Message 11 of 11
jhackney1972
When you are logged into the Forum, you will find the Accept Solution icon on any post that answered your question.  Do not worry about it here, I marked my post, as the solution, for you.  Thanks for getting back to me.
