Placing a twisted wire circle model on a cylindrical object.
g.isley
g.isley
I am trying to place the twisted wire circle on a ring ( or cylinder ) surface.  See enclosed file.  I would like to have all of the model protruding the same height on the cylinder.  I saw one possibility using the sheet metal function which I have no experience with.  Any help would be appreciated.
Replies (25)
etfrench
What are your target ID and OD for the ring?
ETFrench
g.isley
Id 19.26
Od. 20.06
etfrench
I'll start at the end first. 😀  There are several ways of making a solid cylinder or ring from a split sheet metal ring.
One is to create a solid ring, then create a sheet metal ring, then combine the two.  This requires the sheet metal ring to have an OD equal to the solid ring and an ID equal to or larger than the ID.  When combined the split will disappear.  This is the method (mostly) demonstrated in my earlier screencast.
The second is to simply create the sheet metal ring, then use some method to fill the gap.  One of those methods would be to extrude the shape of gap from a sketch on the bottom (or top).  The second would be to use Press/Pull on the inner side of the gap opposite the small extruded section.  Note: This requires setting the thickness of the sheet metal flange to the desired thickness of the ring (It's in the Modify Menu under Sheet Metal Rules).  In your case .4mm.
All of these methods may leave a small artifact from the extruded section. (Extruding follows a straight path while Press/Pull will follow the curvature.)  If the artifact exists it may be removed by simply deleting the faces or by using an Extrude|Cut operation with a profile matching the OD and wide enough to cover the artifact.
ETFrench
g.isley
 Thank you very much. That clearly answers all my questions.
g.isley
Would this be the appropriate place to ask how to twist this link?
etfrench
A new thread will get more eyes on it.  Threads with solutions may not be looked at by some.  You may want to explain what you mean by twisted.
ETFrench
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
