Placing a dimension not at a point
davidSWEUU
Message 1 of 10
davidSWEUU
I have a scenario where I need to grab a dimension but there is no point to use. I cannot figure out a way to force the dimension to a spot along an edge. I have attached the drawing in PDF.
The dimension in question is the "72" It is snapped to the corner, but I need it to dimension to the overall height at that spot. (in other words, it needs to say 72 1/8). I can override the dimension and type in the value, but the other issue is I want the dimension shown as a fraction like it's "70 1/8" counterpart.  ideas?
Replies (9)
Message 2 of 10
jhackney1972
You can do this by possibly adding a sketch point in the model so you can use it in the drawing.  Please attach our MODEL so one of the forum users can create a drawing and show the process.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 3 of 10
davidSWEUU
Thank You!
I haven't used any sketches in my drawings before, so the idea didn't occur to me.  It worked as I had hoped.  It is too bad a similar function isn't built into the drawings mode.
Message 4 of 10
rushabhthakkar_910
So, were you able to Dimension it as you wanted..? If not, attach the File..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 5 of 10
davidSWEUU
Yes, As I stated I was able to create a sketch point as suggested, and then dimension off it in the drawing. I just had to make that specific sketch visible in the drawing so I was sure to use an otherwise empty sketch so there were no extra sketch details that were visible.  Once the sketch was visible, I was able to snap onto it with the dimension tool and use it.
Message 6 of 10
rushabhthakkar_910
Can you still attach the .f3d File..?
Thanks and Regards,
Rushabh Thakkar.
Message 7 of 10
g-andresen
The drawing is derived from the design.
So you dimension the geometry that was created in design mode. Therefore, an "auxiliary element" (e.g. point, line...) must also have a reference to the object.
günther
Message 8 of 10
davidSWEUU
That makes sense. Perhaps the need to reference a "floating point" is not a common situation.
Message 9 of 10
davidSWEUU
Here it is.
Message 10 of 10
rushabhthakkar_910
Sorry for late Reply..
You could also have used the Baseline Dimension option... See this Screencast Video..
Thanks and Regards,
Rushabh Thakkar.
