How to create irregular chamfer?
thejermyn
thejermyn
Hi there!
Does anyone know what is the best way to create a chamfer that connects the 2 highlighted edges shown below? Thanks in advance for the help 🙂
Cheers!
JK
rushabhthakkar_910
As far as I know this is not possible... You want to chamfer and join 2 edges at different height..? How..??
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
TheCADWhisperer
Loft or Patch.
g-andresen
Loft should so that.
Create triangles on both sides and project the highlighted edges to these triangles.
CREATE > Loft > Triangles are profile 1 and 2 and the edges > rail 1 and 2
Günther
thejermyn
Thank you for the quick response everyone! I found the answer as I was exploring the LOFT function with 2 rails as guidelines. Thanks guenther.andresen, exactly the solution you mentioned!
