- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm looking for tips on how to model a pipe/rod structure (solid rod technically, it's not hollow) that changes its cross-sectional shape but maintains a cross sectional area. The part will be compression molded in carbon fiber, so the constant area is important for even compaction.
The part changes from a squarish oval with the long side on the y-axis to a squarish oval with the long side on the x-axis. The rod also makes bends along the way. My plan is to use a loft between multiple cross-section sketches, each manually set with the correct area, but I'm worried that the cross-section area will change somewhat as loft is computed around the bends and as the shape changes. I've tried the pipe command but it doesn't seem to have much flexibility for shape changes.
Is there a more clever or less tedious way to pull this off? I can upload a model later as I make more progress, but wanted to ask before I get too deep.
Thank you,
Brian
