Pipe on a grid with intersecting lines
tripleSheva
Message 1 of 8
tripleSheva
I'm trying to design an enclosure, and I'd like to be able to just `Select Pipe` > `Select all sketch lines` and go. However - because, I assume I have some sharp angles and intersections - it doesn't quite work. Getting the "The sweep could not create a valid body. Try changing the profile or path, or adjusting the operation values." error, but I'm not quite sure what "adjustments" I need to do.
I could probably pipe the outer frame first, and then have another pipe for the inner sections, but I'd prefer to be able to do it in one operation. Am I missing something, or is this just a limitation of the Pipe function?
Replies (7)
Message 2 of 8
davebYYPCU
We don’t know if the Pipe is round, square or triangle profile.
The sketch is too complicated for Fusion to know what you want, single step selections will dictate a result.
Sweep the external boundary to get mitred corners, pipe will not extend past the extent if it’s centre line.
Might help….
Message 3 of 8
tripleSheva
It's a round pipe, but that doesn't matter. The issue is indeed that Fusion doesn't know how to pipe in different directions. I ended doing multiple pipe (join) operations.
Now that I created the component (two copies), how can I create the connecting pipes between the copies, at each intersection of the profile? Creating a sketch for each "elevation" doesn't feel right to me.
Message 4 of 8
davebYYPCU
Of course it matters, square pipes would be extrude.
One sketch, circles at the intersections required, and extrude all joiners.
Might help….
Message 5 of 8
tripleSheva
Sorry, I meant that it doesn't matter for the Pipe command. It cannot handle it regardless of the profile selected.
As for your solution, it works, but it also means I have to manually select every segment of every pipe (almost 50 of them), to extrude this. And if I decide to change my sketch afterwards, I'll have to redo all the extrusions. Is there no better way?
Message 6 of 8
davebYYPCU
The joiners would be in a separate sketch at my place.
Project centre points, from the frame.  Draw, pattern the circles, and Thin Extrude tubes.
Almost 50 of them, huh?  I count 11 in one frame.
When you work smart, you have one frame, copied not a copied sketch.
Might help….
Message 7 of 8
tripleSheva
50 some pieces, yeah. Because the lines break the circles when it's all in one sketch. 😄
I didn't want to create another sketch and project so many points onto it, but I guess that's the way to go. Thanks!
Message 8 of 8
davebYYPCU
Not for me to stop you doing it any way that suits,
lots of simple sketches will make Fusion happier than you.
Might help….
