Pipe Oddity
Pipe Oddity
tmostad
Pipe Oddity
tmostad
I am creating a pipe and the preview looks like this (which is what I want):
When I click OK this is what I get:Ashampoo_Snap_Monday, December 9, 2019_12h00m19s_002_.png
I don't understand why the triangle turns/changes shape (whichever it is doing)?
davebYYPCU
Sweep - or Pipe command?
Sweep needs you to make the Triangle in a sketch,
Pipe command has no control for the triangle - roll angle, it is default to place the vertical leg on the path.
Might help....
tmostad
Oops, you are right. I couldn't figure out the sweep command so I switched to pipe -- and promptly forgot. I will edit the title of my post.
I find it curious that that the preview is not accurate for the final result. Plus having no angle choice makes anything other than a round cross section marginally useful. I suppose I'll have to go back to figuring out how to use sweep.
davebYYPCU
Sweep is far more versatile.
As a beginner, you have the path, the sketch should be (normal) square to the path and the path (and rails) should Intersect the sketch.
Basically you can draw any triangle as a cross section sketch, for the end result.
Might help....
TrippyLighting
This is another instance where the preview fails to show what the real result is going to look like 😕
