Message 1 of 11
- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
Hi, I am not sure whether this is the correct board that I am posting this.
I'm new to Fusion 360 and am trying to build a frame from 22.2mm diameter aluminum tube and 3d printed corner joint. The corner joints are where I am having a problem, as I cannot work out how to draw the joining spigots between the top and bottom frames.
I have drawn a sphere off 22.2mm and managed to draw the two spigots at 90deg to each other join the sphere but cannot work out how to construct a new plane in order to draw the third spigot at the required angle.
Please see the attached.
Any help would be appreciated.
OS: Windows 10
Version: Fusion 360, 2.0.7438, Personal
Regards
Dave
