pin-slot joint animation
Can anyone help me diagnose my problem? I want to animate my joint but Fusion says no. This design is for a telescoping leg. The outer tube (component: Slot) has a path for the pin of the inner tube (component: Pin) to slide through and rest in notches that allow the leg to hold position at different heights. I want to animate the “Pin” sliding through the “Slot”. To do this I am using the “Planar” joint type in combination with Tangent Relationship (also in the Assemble menu). In the attached picture, you can see the sketch I embossed to create the “slot”.
I know the Planar joint type will work with curved slots on flat surfaces. But my design is cylindrical and I’m a newbie. Is my request beyond the programs limits? Or do I need to find a way to create a true slot on a curved surface different from my emboss method?
Does using the “emboss” approach mean that it’s not a true slot. I can’t choose the full inner surface when selecting it and the pin to create a Tangent Relationship. I haven’t found anything on working with splines (then offsetting and closing the sketch and extruding to create a slot) either.
