Pin roller joint constraint
I want to introduce a pin roller constraint on the hole in the attached picture, so that it can rotate in the tangential direction and translate in the horizontal direction for a static stress simulation.
TheCADWhisperer
What problem are you having in doing what you state?
Can you File>Export and then Attach your *.f3d file here?
I want to allow x-direction translation on the right hand-side pin as well as rotation about the tangetial direction, efectively modelling a rolling pin constraint. Im attaching the file.
TheCADWhisperer
The original sketch does not meet my quality standards.
I will bow out of this discussion.
Hopefully others will respond.
