Pictoral representation of center to center and center point slot are the same
scottfavaro
scottfavaro
Hi all,
I hope that a fusion developer can see this. I just wanted to let it be known that there is an error that the center to center slot type and center point slot type have the same pictoral representation. It's annoying when I am going fast. That is all.
jhackney1972
I cannot see what you show, either in the Sketch Palette or in the command drop-down menu.  Maybe,if it is important to you, use the Service Utility and the Repair Option.
John Hackney, Retired
TheCADWhisperer
I see the issue on my machine...
Windows 11 OS
a.laasW8M6T
Hi All
Its a Bug with the new themes, Specifically the Light Gray,  Dark Blue and Fusion Classic don't display this issue.
I believe its already been reported and logged
Andrew Laas
Senior Machinist, Scott Automation
