Physical properties out by a third?
Hi
I have assigned mdf to a model and the properties say its weighs just over nine kilos but I have wieghed an actual board and it is on 5 kg.
Why such a big margin of error ?
I understand different manufacturers would mean there would be variations in density but not by nearly 2 times ?
Many thanks.
ps same happened with a box steel section test i did.
Glenn
TrippyLighting
I've done thins before on an assembly with 400 components including Plywood and Gatorboard and the overall weight was pretty accurate.
I'd have to say that I measured the densities of these materials myself and used that for the properties dialogue.
Could you share your model so we can take a look at it ?
