performances issues
performances issues
jean-michel_legoff
Message 1 of 10
performances issues
jean-michel_legoff
We have some performance issues with Fusion 360 when holding complex designs.
For example I have an assembly which take 8/10 minutes to "recompute" on a Dell Precision 5560.
On the other hand, looking the perf monitor, it looks like the CPU is only at 10/12 % of use... and the memory less than 50% 28Gb for a total available of 64... (CPU is i9 at 2.6 Ghz)
So what are the key performances for a computer to run Fusion 360 faster?
Many Thanks
Replies (9)
Message 2 of 10
g-andresen
@jean-michel_legoff wrote:
So what are the key performances for a computer to run Fusion 360 faster.
1. CPU speed
2. CPU speed
3. CPU speed
günther
Message 3 of 10
TrippyLighting
Recomputing the timeline mostly stresses the geometric modeling kernel of a CAD system.
In case of Fusion 360 (and Autodesk Inventor) that is ASM or Autodesk Shape Manager.
The math and algorithms involved in these kernels don't lend themselves to multicore parallel processing, so most of it is single core. That is particularly true for design history based parametric CAD software.
So as @g-andresen has stated single core main clock frequency and boost clock frequency are the main contributors.
Message 4 of 10
jeff_strater
I will add:
4) design practices
This may even be more important than anything else.  Things like:  Don't use sketch patterns for any significantly sized patterns.  Or, don't put 2000 local components in your design (partition sub-systems into external components).  How you use Fusion is perhaps even more important than what kind of computer you are using, or its capabilities.  No matter how fast of a computer you have, if you are using it to do inefficient things, you will always hit a performance ceiling.  And, on the other end - there are people productively using Fusion on much-less capable machines that are successfully designing significantly-sized designs.
Jeff Strater
Engineering Director
Message 5 of 10
TrippyLighting
@jeff_strater wrote:
I will add:
4) design practices
In my humble opinion, that covers 90% of the performance problems people encounter with Fusion 360.
All too often, however, that feedback is not received well ...
Message 6 of 10
g-andresen
Hi Peter,
Fully agree.
This can not be repeated often enough.
günther
Message 7 of 10
TheCADWhisperer
Key: Computationally inexpensive design techniques.
@jean-michel_legoff
I will make significant wager that if you Attach one of your problem assemblies here - the experts will find multiple computationally expensive issues that can be remedied.  The problem is almost always the techniques used.
Message 8 of 10
TheCADWhisperer
@TrippyLighting
Not just your opinion.
Your expert experience backed by numerous verifiable examples.
Message 9 of 10
jean-michel_legoff
hello,
Is it normal too that the CPU is charged only at 20/25 % and the Memory less than 50% of the computer?
Message 10 of 10
TrippyLighting
Yes! I explained the reasons for that in a post above.
Please do not use the quick reply function at the bottom of the thread. It makes it hard to determine who you are responding to.
