- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear community,
I have recently started using Fusion 360. I would like to illustrate different types of warehouses in 3D. Since I want to show different views, it is not enough to draw the warehouse in 2D.For this I need to sketch a rack, some loading units and simple vehicles. All the bodies used are very simple (cuboids and cylinders).
Modeling a load unit (box) and a shelf is not a problem. If I now try to build up my warehouse via copy and paste, I run into difficulties. The program starts to lag and eventually crashes.
- Is there a limit to how many bodies can be created at the same time?
- Are there any tricks to increase the performance/draw more objects? Reducing the complexity of the objects (cuboids instead of detailed box) did not help.
- Is fusion 360 suitable for the task or should I look for another program?
The following screenshot shows a first try. Here I can already barely select the objects without the program lagging heavily. Adding shelves, aisles and vehicles is not possible.
Please let me know if you need more information.
Best regards
Nicolas
