Performance Issues on Macbook Pro 15"
Message 1 of 18
I have huge performance issues on my brand new MacBook Pro late-2016.
My specs are:
i7 2,7 GHz Quad-Core
16GB 2133 MHz LPDD3
Radeon Pro 455 2048 MB
512GB SSD
So it's really not a slow machine. Not the fastest in the Apple store but certainly not slow.
However when I open the Tabby platform model (supplied here: https://www.osvehicle.com/download/ ) Fusion become unusable slow. I already researched performance issues about Laptops with 2 graphics cards and this didn't help, I looked into other threads about performance issues and even activated the "Limit effects to optimize performance" option and it didn't help...
Opening the file takes about 90 seconds and panning and zooming is so incredibly slow...
What can I do?
Thanks!
Jakob
Replies (17)
Message 2 of 18
O.Tan
Hmm, I have the Late 2016 Model (see my signature), so I don't mind giving it a shot, mind adding me into your project?
And I just looked into the video you shared, it seems that the model is converted from a surface file (something like from 3Ds Max) then a solid STEP file, cause it seems to have many surfaces and isn't a solid model.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Message 3 of 18
Hi Omar,
Sure, no problem.
Can you pm me your email?
Jakob
Message 4 of 18
O.Tan
Just sent, check your PM
Omar Tan
Malaysia
Message 5 of 18
Done! Sent u an invitation!
Message 6 of 18
chengyun.yang
I am a developer from Autodesk. Can you also invite me to your project? My email address: [email protected]
Chengyun
Message 7 of 18
Check! Done!
Message 8 of 18
chengyun.yang
Thanks, I took a quick look at your model and I think the major problem is in the component none:1, there are more than 10000 unstitched faces. This is something Fusion really doesn't handle well. For each of these faces, currently Fusion generates one body for it, which slows down the performance significantly. If you set them to be invisible in the UI browser, I am sure the performance will be much better.
Also, please try to make sure you use OpenGL core profile driver in the Fusion preference dialog.
Chengyun
Fusion Development Team
Message 9 of 18
O.Tan
Just checked your model, the issue mainly lies on the Unstitched Surfaces. I already recorded a screen cast on my side, but still waiting for it to upload.
TL;DR: Basically you need to stitch those surfaces up, but I'm not sure how to do that when the software becomes that slow. Hopefully some other surface experts will be able to come help you out.
@cekuhnen
 Sorry for the sound.
Omar Tan
Malaysia
Message 10 of 18
Hey guys,
Yup, that's right, that solves the performance issues and I totally get that these unstitched surfaces get any CAD program into trouble. I'm wondering though if this is really a problem of the file or if it might be an import problem?
In my original message I posted a download link for the original files (they're open source). Maybe, you Chengyun can try to import this file yourself and see if the file or the import is the problem.
Thank you for your help though! 🙂
Cheers,
Jakob
Message 11 of 18
cekuhnen
@chengyun.yang
Thanks for the info that unstitched surfaces can slow Fusion down based on how it works with them.
That makes sense and is also valuable information!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 12 of 18
O.Tan
What was the original file format in?
Usually the issue is cause the model was modelled in a polygon modeller and then exported, leaving behind broken surfaces and when imported into CAD softwares, will require to be manually fixed.
Omar Tan
Malaysia
Message 13 of 18
I'd doubt, that Renault (the original designers) designed this in a polygon modeler and then suggest to use FreeCAD for opening their files...
The original file is .stp
Jakob
Message 14 of 18
O.Tan
Okay, can you attach the step file here? cause I visited the site and all I saw is 2 seats or 4 seats to download the file?
Tomorrow I'll try to import it into SolidEdge and see how it converts the file, if all is well, I'll convert it into a STEP file from there and put it into your Fusion project.
Omar Tan
Malaysia
Message 15 of 18
Hey,
They file is too big to attach here. Just download either model. Both have the same problem.
Thank you for looking into this!
Jakob
Message 16 of 18
chengyun.yang
Yes, I have tried to import the original file into Fusion and I got the same result with more than 10000 unstitched surfaces. In my opinion, for this kind of case, Fusion should try to stitch them together as part of the importing process. But I also understand some users might not like the default auto-stitching. So one reasonable solution will be to provide a UI dialog so the users can choose how they would like the model to be imported. However, this is not something Fusion supports for now, as Fusion does all the importing on the cloud. This has been discussed inside Fusion team and there is a plan to support it in the future but I am not aware of the detailed plan. @jeff strater, @colin smith
Chengyun
Message 17 of 18
TrippyLighting
I bet most of these unstitched faces are in the tires. If you don't need them, then delete them.
Message 18 of 18
Hi guys,
I am having serious issues on my late 2015 MBPro (i7 3.2GHz, 16GB Ram, SSD). Doesn't really matter which project I load, after a minute or so, the fan turns on and doesn't stop. After another 5mins the app gets completely unresponsive, hourglass etc. I have set the graphics effects off. Even with NO project loaded I can hear the fan turning slowly after a while. Already re-installed Fusion.
Any thoughts ?
Thanks !!!
