- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I recently learned how to utilize Motion Links in Autodesk, but I've been encountering some performance issues. While a single Motion Link works seamlessly, using three or four simultaneously causes noticeable lag and stuttering, both on my Mac M1 and my powerful PC (i7 9th Gen and RTX 2080). I'm wondering if this behavior is normal or if there might be something I'm not doing right. Here's a design where I'm having this issue.
Additionally, I'm planning to create a smooth video of my design in the Animation tool. However, when I switch from the Design tool to the Animation tool, the joints and all the motion links I've worked on seem to disappear. Furthermore, I've been struggling to make my spiral turn relative to its own rotation axis in the Animation tool since the "transform" option is kind of hard to work with. Is there a way to render a smooth video of my design while keeping the joints and motion links active?
Thank you in advance for your help!
Best regards, Erwin MARTIN
