Patterns
Patterns
chadN693J
Patterns
chadN693J
How do I get equal distance between the edges and the holes after creating a pattern?
aliobidi
Hi ,
make the first hole on the center of the shape
then make your pattern with symmetric
if they even numbers you need draw a sketch with dimensions
aliobidi
or you can start first hole near form the edge of the geometry and change " distance type " to " spacing "
but in this solution u need to know the length of this edge and make some math
chadN693J
Didn’t think of that. Thank you!!
aliobidi
Do not forget to Accept Solution since you have your answer. This helps others find the solution to similar problems.
