'Pattern on Path' Feature Occasionally Working Incorrectly
darrenEZWXR
darrenEZWXR
Part of my design work involves creating serrations on the back of blocks.
I am aware of the various methods to create these, I have chosen to...
'Sketch' the single serration, 'Press Pull' it through all then use 'Pattern on Path' to create the full serrated line.
However, occasionally this feature seems to incorrectly only create a single additional serration at a random position on the path once I select 'okay' on the 'edit feature' box.
Incorrect Serration that Occasionally AppearsIncorrect Serration that Occasionally AppearsEdit/Preview of the Desired PatternEdit/Preview of the Desired Pattern
Phil.E
Sorry for the trouble. This is a known issue with Edit of Pattern on Path. The workaround is usually to recreate the pattern entirely rather than edit it.
I'll add your comments to the bug report. Please let me know if you have more questions.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
