Pattern on complex path
DanGriffinSTA8Y
Message 1 of 15
DanGriffinSTA8Y
The image below is a sketch of simple lines with good intersections.  I have been able to use Pattern on Path for each line individually but is there a way to create a pattern along every line in one operation?
Replies (14)
Message 2 of 15
lichtzeichenanlage
Create a path for the full length...
Message 3 of 15
DanGriffinSTA8Y
I was afraid that was the only answer...
Message 4 of 15
TrippyLighting
What kind of pattern would you want to create and what is the final look you are looking for ?
Message 5 of 15
DanGriffinSTA8Y
The lines will be populated with small spikes creating a Celtic knot pattern to be applied to leather for tooling.  (to be 3D Printed)
Below is my first attempt using a bevel edge which didn't work very well.  The leather patterns that you buy use lines of pips to create the pattern.  This model took WAY to long to create the edges.  I really don't want to go through that again.
When the "body" of the pattern is created using EXTRUDE the cross lines delineating the "cords" going under and over each other are lost (as you can see) which causes problems, so I am attempting to make the spikes first and add the body last.
Message 6 of 15
TrippyLighting
Spikes, or more or a continuous sharp edge that will be pressed into the leather. Either way, if you can share the model I'l see what I can do.
Message 7 of 15
DanGriffinSTA8Y
Sure.  What format would you like?
f3d
iges
sat
smt
step
Message 8 of 15
DanGriffinSTA8Y
Since there is no attachment option, I guess this is the way you do it (?)
https://a360.co/2QtcZJt
Message 9 of 15
TrippyLighting
Yes, the download link also works.
So do you mean a sharp edge such as in the image, or do you mean more pyramidal spikes ?
Message 10 of 15
DanGriffinSTA8Y
Pyramidal spikes, the sharp edges didn't transfer the pattern very well.  Too much surface area I believe.
The lines are the center-lines of the pattern to be transferred to the leather.  About 2mm high and wide with a little spacing.  Then I was going to put a 5mm backing plate under them.  (I was constructing it in the spikes up orientation although it is to be used in the spikes down orientation of course.)
Please note that there are lines in the 2D drawing that indicate where the straps of the Celtic knot go over and under each other.  An important part of the design which was lost in my first attempt (the 3D image I first posted).  And, since this is only a portion of the total length of the pattern, to be chained one after the other, there are a few lines in the 2D drawing that need to be "left out" of the final 3D model.  So, I need to know how this is done, and/or, be able to delete some of the spikes in these areas to end up with an appropriate pattern.  (actually, this is the "end pattern".  I need to make a second one, almost identical, that is the "chaining pattern")
FYI: This is for a guitar strap for my grandson, for Christmas, who has just taken up the guitar.  And this particular pattern isn't available for leather tooling from the usual suppliers.  So I'm having to make one.  Needless to say, your time and effort is greatly appreciated.
Sincerely,
Dan Griffin
Message 11 of 15
TrippyLighting
Just so you know, I've not forgotten about this.
The problem in your design starts with your sketch, which has a number of overlapping lines. It also is not properly constrained, which would make getting to your desired result very difficult.
The pattern has many symmetries and it was not trivial to come up with a sketch that is fully parametric so this can be patterned.
This is the base sketch which is driven by user parameters:
More later.
Message 12 of 15
DanGriffinSTA8Y
I appreciate your time and trouble.  Your last post alone was an eye opener.  Fusion is a powerful tool, and as such has to be used with respect.  Not unlike Photoshop CS.  Which brings me to the crux of the situation.  Just as you wouldn't use an Haas VF3SS to spin yarn, I have found that for my menial needs in this case Sketchup is a better tool for the task.
Thanks again,
Dan Griffin
Message 13 of 15
TrippyLighting
Very cool!
Please post the end results.
Message 14 of 15
DanGriffinSTA8Y
Thanks again.
Message 15 of 15
TrippyLighting
Beautiful work!
