Pattern along a path issue
haniysf
haniysf
I want to do a feature pattern on path (replicate split body), after I choose the feature from the timeline and the path, the Blue arrow appears at the opposite end of the path, why is this happening?
BR
Hani
Beyondforce
Hi @haniysf,
If you could make a screencast and attach the file, that will be very helpful!
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
haniysf
Hi Ben,
As I was experementing, the issue got solved when I added a second feature to the pattern. I started by trying to pattern a body split which resulted in this unexpected behaviour, then I thickened the resultant split surface and added it to the pattern selection, and it worked like a charm. Unfortunately, I did not capture a screencast for it.
Thanks and regards,
Hani
