Pattern a Hole (Feature) doesn't work!
Beyondforce
Advisor Advisor
Message 1 of 8
Beyondforce
Hi Guys,
Maybe you can figure this out. I'm trying to pattern a hole feature, but it doesn't work. Maybe I'm doing something wrong!?
I have attached the file as well.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Replies (7)
Message 2 of 8
daniel_lyall
 Where are the the features for the hole
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 8
Beyondforce
What do you mean?
Ben Korez
| YouTube
Message 4 of 8
TrippyLighting
The compute option will not do much in this case.
The problem is that when patterning an feature you need to pattern it in the same body. The feature that you want to pattern would end up in different bodies.
Message 5 of 8
Beyondforce
Make sanse, I completely forgot about it.
Thanks @TrippyLighting
Ben Korez
| YouTube
Message 6 of 8
jeff_strater
What I do in these cases is, instead of creating a hole, create a tool body, use pattern body to pattern the tool body around, then do a series of Combines to subtract the tool bodies from the target bodies.  It's not ideal, but it will work.
Jeff
Jeff Strater
Engineering Director
Message 7 of 8
daniel_lyall
the other way is to just pattern the body with the hole in it but that's yuck
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 8
Beyondforce
@jeff_strater & @daniel_lyall,
What I did is, I removed all the bodies except for the one with the hole, then I patterned the body with hole. It works great this way.
Now I can change one body and it will replicate to the others.
Thanks guys.
Ben.
Ben Korez
| YouTube
