I'm trying to create a Patch surface using a sketch that has 2 or 3 profiles or is divided in 2 or 3 profiles so when i select all the profiles inside the sketch instead of create one single patch/surface it creates multiple surfaces/bodies instead, is there anything i can do to make sure i get a single surface?
thank you for the help
just from what your saying you should just be getting a single surface, but it's really hard to tell with out seeing anything. attaching a model (export a .f3d) or some screen shots, or a screen cast would be helpful
