Patch on converted mesh
rickyburtonsmith86
rickyburtonsmith86
I am after some advice on how to achieve something.
this is the geometry in question, That I  have imported as .obj and converted to solid.
I have tried to patch the bottom but this is failing to work is there a workaround?
jhackney1972
Please attach your model.  Open it is Fusion 360, select the File menu, then Export and save to your hard drive.  Attach the file to a reply post.
John Hackney, Retired
rickyburtonsmith86
hi see attached
jhackney1972
I do not think you will have much luck with your model using Fusion 360.  Maybe you will have better success using Meshmixer or some other surface application.
rickyburtonsmith86
Thank you, I will give meshmixer ago.
jeff_strater
The Fusion mesh environment has some of the same capabilities as Meshmixer.  In this case, you may be able to use Mesh Repair to close the hole, as shown in the video below.  So, close the mesh in the Mesh environment before conversion:
Jeff Strater
Engineering Director
rickyburtonsmith86
@jeff_strater perfect, did the job nicely very clean workable model.
