Patch command not working while not showing any errors
evrensili07
Observer Observer
evrensili07
Observer
Observer
1.
 2.
Hello, I'm trying to create a surface with the patch command, seen in the first image. I created a very similar surface with patch as you can see in the second image but it had different dimensions than the one I'm working on right now. I'm guessing it is about tolerances of fusion but I'm not sure. Any help would be appreciated! Thanks in advance!
You can find the new model in the attachments.
TrippyLighting
The patch command isn't really the right tool for the job. A loft would be better.
