- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a conical surface on which I placed a Tangent Plane, centered quite nicely on that surface.
An overhead view shows that the plane is nicely centered along the vertical center of the conical surface.
I then created a Sketch using that plane.
When that sketch is extruded into the Component it creates a nice little "notch" at the bottom of the Component.
then
So far, all is well. There are NO WARNINGS anywhere in the timeline.
I then make sure that I have this Component (ConeShingleUpperMaster) selected as active, and do a Copy operation.
I then Activate the overall project and do a Paste NEW.
A dialog pops up, BUT the first thing I notice is that the tangent plane (on the NEW-ly copied component) that I had created for the notch sketch seems out of place, angled and shifted to the left. The original plane is light yellow, the copied plane is gray. SOMETHING VERY WEIRD.
In the dialog I select the ROTATE Move Type, select the main axis of the project, 60 degrees to rotate, and Capture Position.
That results in this...
And as you can see, the tangent plane that I had defined in the original component for use by the notch sketch is WRONG in the NEW copy of the component, it's weirdly displaced, with the corresponding sketch also displaced.
Here's an overhead view of what the tangent plane looks like in the COPY.
That tangent plane is SUPPOSED to be centered on the surface, but instead it's somehow SHIFTED off to the left edge of the surface.
I've tried all sorts of approaches and nothing works. The tangent plane always gets weirdly shifted in any PasteNEW of a copy of the original.
I've attached a copy of the project to this message. It has JUST the original Component, so you can try the Copy/PasteNEW and see how weird the tangent plane ends up.
The Component is called "ConeShingleUpperMaster".
The plane Construction is called "PlaneForBottomNotchMiddle".
The Sketch is called "ConeShingleBottomNotchMiddle".
