Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Parting lines?
6 REPLIES 6
Oceanconcepts
676 Views, 6 Replies
Parting lines?
Is there a simple way to generate a parting line?  I want to see if I'm missing something before posting this as an idea station request.
Ron
- Ron
Mostly Mac- currently M1 MacBook Pro
6 REPLIES 6
For molds?
Could you use a workplane or surface with the split body command?
Nathan Chandler
Principal Specialist
What I'm looking for is a way to find the "natural" parting line on a complex, organically shaped body, referenced to a particular pull direction or plane.  Other CAD packages I've used have a "find parting line" command.  I'm trying to figure out how to find this curve in Fusion.
- Ron
This is in progress as we speak. Should be available for our September update.
In the mean time you can approximate/visualize the natural parting line by using the draft analysis command, set a pull direction and then set all the values to -.01 deg and .01 deg
Kevin Schneider
OK, draft analysis is what I have used to approximate, but it doesn't generate a curve I can pick up and use for construction, splitting, project to a sketch, etc.  Good to know this is coming.
Ron
- Ron
If you need something right away, you could send me an F3D and I'll split the faces for you along the natural parting line.
Kevin Schneider
Thanks- What I'm doing is good enough for now, and it sounds as if the tool will be there when I need more precision.  I just wondered if I was missing something.
Ron
- Ron
Technology Administrators
