I am trying to draw a sketch based on some calculations i do within my parameter list.
I drew a component wich is 7mm thick, 150mm high and 471,239mm long. this part is curved with a radius of 600mm. I converted it to sheetmetal, made a flatpattern. Then when you openup the parameter list it is completely empty. If you make a scetch you can't even open the parameter list. What is the reason the list doesn't show up in flatpatern?
Thank you in advance
Solved by TheCADWhisperer. Go to Solution.
I am not at my Fusion machine to check - but shouldn’t you be in Unfold rather than Flat Pattern?
It is exceedingly rare to be editing anything in Flat Pattern state.
