Good morning,
I am very new to fusion but and experienced carpenter. I have made a parametric design of a staircase. So far so good, there are issues:
1. I just cant figure how to even out the distance of my steps to both top floor and ground floor, and between each step. I use the numbers of steps as a parameter, is there a way to calculate this automatically? For instance, if you build a step, the distance going up should be between 17 and 21 cm for an ideal staircase. I have thought about drawing the first and last step manually and then filling the void with a rectangular pattern.
2. It would be a great thing to just measure the height of the finished floor and the staircase opening and apply these parameters in fusion and have all the stairs evened out.
3. From what I have read, the aim is to recreate seperate components, how can I easily generate a parts/cutting list?
Thanks all, Have a good sunday
