Parametric Patterns
Parametric Patterns
Message 1 of 8
Parametric Patterns
Hi all!
I'm wondering if it's possible to create parametric gradient patterns with Fusion 360 like the ones created with Rhino and grasshopper or something like that?
4d8b32121df69eee95c7524de7e8205a72eb5064ff6eb2cbf308bd4bee910680
Replies (7)
Message 2 of 8
TrippyLighting
Unless you are pretty well versed in python (or java Script or C++) and the Fusion 360 API and can write a plugin for Fusion 360 then I'd say NO.
This form of generative design I would love to see in Fusion 360 as well, but I not see that happening in the foreseeable future.
Message 3 of 8
That's a pity! 1 point less for fusion!
Message 4 of 8
Beyondforce
Nevertheless, I think you should put it in Idea Station. I will vote for it.
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 5 of 8
TrippyLighting
I will definitely vote for this as well!
Message 6 of 8
I found it in The ideas station! someone asked for it already two years ago. You can find it by searching parametric pattern, it is the first result. You can vote for it
Message 7 of 8
JYZMT
I have also voted. Thanks
Message 8 of 8
chrisplyler
It's not the same, but I've been able to approximate such a thing by patterning on a path.
In this image, a cut feature is patterned along an arc to produce grooves of changing depth. There is some other stuff going on also, but the pattern on a path is the relevant bit.
