Extrude a text to multiple faces
Nickduino
Nickduino
I wanted to extrude a text 0.5 mm. Seems I can do it with one face, not a multiple selection?
patilsm
Hi @Nickduino,
As per your comment ..You are intersted into multiple text surface extrude, Right?
If your answer is Yes, then we can do multiple Text surface extrude by using Ctrl key.
If you are looking for something different, then please let me know.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Nickduino
Well I tried that, it seems it deselects the first surface and selects the
second one only.
patilsm
Please check attached screen cast where by using Ctrl key for window and Command Key for  Mac we can select multiple text and extrude it.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Nickduino
Oh, I wasn't clear!
I want to extrude only one text on several adjacent faces.
Brady_Fulton
After you do the first one, you'll need to turn the sketch back on and then repeat the extrude command as many times as you have faces you want affected.
There is a setting in the properties to have the sketch remain on after the extrude command is used if you want that functionality.
Sharing a screengrab of Fusion showing your window and timeline would help in this situation as well.
