Parametric modeling like Grasshopper
Does anyone know if something like Rhino's Grasshopper will ever make it's way to F360? Parametric modeling is possible, but not sure if we can put in entire lines of math and have Fusion work it all out. Having a wrapper with nodes like Grasshopper would be great.
On that note, has anyone ever think of developing a Grasshopper similar plugin for Fusion?
I would love to make small generative pieces, but Rhino is way out of my budget.
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting in the community!
Did you try Dynamo Studio? It is a graphical algorithmic editor like Grasshopper for Rhino.
Since Dynamo is a standalone application, the below add-in would be necessary to connect with Fusion 360:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=74731490955641349&appLang=en&os=Win64
I hope the below document may help you.
The Dynamo Primer
http://dynamoprimer.com/en/index.html
Thanks!
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Hi Saito,
Yes I actually discovered Dynamo yesterday. But the open source version only works with Revit.
