Parametric Design and Circular Pattern Item Extrusion
wedontplay
wedontplay
Hi, I'm learning Fusion and as an exercise I'm trying to design a fully parametric geneva wheel.
I had no problem in making the sketch part assigning formulas and constraints to sketch dimensions.
The problem I have now is with the extruded bodies.
I used a circular pattern to duplicate the sketch elements accordingly to the desired slot quantity how can I have the object part react accordingly?
The only thing it happens is that object are deleted when I lower the pattern element number, but if i use an higher number object are not created anymore.
I think I'm doing it wrong, what is the correct way to accomplish that task?
Tx.
HughesTooling
I think what you're doing wrong is coping the sketches, you need to make copies or the features. Here's an example.
I've made an assembly of a 1:1 timing gear and belt and changing the number of teeth in the parameters dialog updates everything OK.
Mark
Mark Hughes
Owner, Hughes Tooling
