I'm just checking out Fusion 360 -considering moving from Solidworks. So far there are very many things I really like, but I've hit a weird dead end:
As far as I can tell there is no way to create parametric components - in other words to create different instances of a component with different parameters.
Can this really be true? Do you have to make a new model of a bolt every time you want one a different length? Do you have to model every standard bit of tubing (with radiuses etc.) every time you want to use one?
I'm especially baffled because designs can have "User parameters" - so allowing parametric instances doesn't seem harder to implement than just allowing people to expose the parameters they want to change as User Parameters, and then allowing them to be edited for each instance. But I've tried every way I can think of, and it just doesn't seem possible. It seems bafffling to make parametric modelling software, and then not bother to use the parameters for something so obvious and essentially useful as this.
Am I missing something really obvious? Otherwise how do you actually cope with what seems to me to be a massive miussing piece of functionality? Is there a totally different paradigm that I'm misunderstanding?
