Parameteric models using Conics and Splines
- Mute
- Permalink
- Report
Ok, this is a mini-rant.
Please do not ask me to post files, they are all proprietary until I make a complete model to illustrate the problem.
Parametric modeling ALWAYS fails when using Conics or Splines. 2d and 3D sketches with conics and splines fail 100% of the time if any parameter is changed related to their positions.
I have basic parameters for an object that I need to fit around, so I have created the bounding box using parameters. These parameters are used to drive sketch dimensions. I create basic geometry and use conic curves for some of the corners to attempt to have some semblance of curvature continuity.
Basically, if I change ANY parameter, the sketch dimensions turn red and refuse to solve. The only solution is to delete the conic and re-sketch it. This, of course, is not acceptable as these are the control curves for lofts.
If there is anything with a tangent or curvature continuity in any sketch and and a parameter gets changed, the whole model fails to solve and requires a complete manual rebuild. I have noticed that all of the magical tutorials on the internet that show stuff like this working do not use conics or control point splines.
How am I supposed to make constraints so that parameters can be changed and still allow conics and control point splines to function properly?
Surfacing is a whole other problem that will need a separate post.
