Had a strange thing happen on a assembly model I have been working with on and off for quite a while. Took me a while to figure out how to fix it so I thought I would share what I found and maybe help someone else save a little time. I could not find any reference to the issue on the forums.
I went to use a variable from early in the model (d39 to be exact - I am up to 720 or so) and the parameter would not be taken as an offset in a joint I was trying to make. It would just stay red in the input box like it does when the units don't match or the variable or user parameter is not recognized. It would not be taken for anything else either like a dimension in a sketch. I knew it was there I could see it in the parameter list.
Here is what I found:
This is what parameter d39 looked like in the parameter listing. (I am working in fractions.)
Linerar Dimension-2 d39 in 5/16" 0.3125
So I clicked on the expression [5/16"] and changed it to 3/16. By the way when I selected it, it turned red like it did not understand it. I typed in 3/16 hit enter and lo and behold it updated the model and the expression entry changed to (3 / 16) * 1 in. I changed it back to 5/16 and the model updated and it reads as you might have guessed (5 / 16) * 1 in and all is now right with the world. I can use as a parameter.
I also note that the more recent linear variables I have made are already in the updated (?) format.
I suspect maybe that the way 360 handles units was updated at some point in time to a new method and old variables are getting stuck but who knows. At least I (we) know haw to fix it now.
Solved by jeff_strater. Go to Solution.
Hi @matt.soule, thanks for the post. Interesting symptom. I don't remember a recent change, but if you've been using this assembly for a while, the Fusion change could have happened a while ago. Thanks for your diligence in digging in and finding a workaround and posting it.
If this is a model you can share, can you send me a link to the older version that showed the problem? I'd like to take a look at it to see if we can pinpoint when this happened and whether we should take any action to try to auto-correct expressions like these if we run into them in the future.
Jeff
