parameter changes using one center axis point reference
Message 1 of 8
how to fix one axis point in parameter to control dimension or to distribute equally
Replies (7)
Message 2 of 8
Lynn_Kim
Can you explain it with an example?
린킴 Lynn Kim (Fusion 360, Dynamo)
Message 3 of 8
hpekristiansen
You can use the symmetry constraint. Here is a rectangle where the end are symmetric about a centerline. The dimension(100) can also be a parameter:
Message 4 of 8
I tried symmetry constraint also but when I change dimension in parameter ,
length don't change from the centre point.. my whole design get disalign
Message 5 of 8
hpekristiansen
Try to make sure, that your centerline(symmetry line) can not move(make it black or green) by adding dimensions to it, or by right click and choose "Fix".
Message 6 of 8
jeff_strater
seems to work for me:
Jeff Strater
Engineering Director
Message 7 of 8
hpekristiansen
I am very confused. Why are you writing this to me? I know how to use Fusion 360.
Message 8 of 8
jeff_strater
Sorry, @hpekristiansen - I just replied to the last post in the thread.  It was meant for @Anonymous
Jeff Strater
