panning with trackpad is slow
vacljan
Message 1 of 32
vacljan
Hi there.
I have an issue with trackpad panning. First of all, I use magic trackpad on my mac with macos Sierra.
Here is the issue. When I use panning gesture with two fingers the object is moving really slowly. I have to drag across whole trackpad many many times to get it on position I want. When I click on ,,pan hand" simbol down below (where obit is and so on). Then click by one finger pan is working fine and object is moving fast and exactly with mouse.
Is there any possibility to set up the speed of moving or so?
Than you for your advises.
Sincerely
Jan
Replies (31)
Message 21 of 32
tranq006
Has anyone noticed improvements to this? I have a new Macbook Pro and the same issue - super slow panning with trackpad.
Message 22 of 32
lance.carocci
We have not directly addressed this from the Fusion side yet, but it's still on our radar.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 23 of 32
it-ony
How likely is it that this will be addressed in short time? Having it on the radar is good but sounds like it doesn't have and priority. By fixing this fusion becomes directly more usable for any mac user. It's a major ux problem and using a mouse is not a solution for me.
Message 24 of 32
lance.carocci
There are a hierarchy of trackpad-related issues to address, and panning speed independent of the OS is on that list. But, it's still below things like the Windows trackpad functionality, which currently does not exist at all.
There's no hard timeline for that, either, but that's something I am trying to lock down. Hardware input and gestures technically fall under our UI framework development, so we're also balancing with the need to fix existing bugs like macOS Spaces and the pop-through Browser/Comments frame.
Lance Carocci
Message 25 of 32
vendorsFZR2A
Observer
Observer
Having the same issue, making working in fusion 360 extremely slow and annoying...
Message 26 of 32
tranq006
I figured out the solution (at least for my case), try re-homing the view (upper right hand corner) when you are having this issue, and then go back to the view you were at and try panning. Fixed it for me
Message 27 of 32
it-ony
@tranq006 thanks, this works. @lance.carocci because re-homing fixes the issue part time, this is a clear indicator that fusion calculates some kind of factor based on orientation / zoom level that gets stuck at some point.
So, should be fairly easy to fix it then. Please make it a priority as it's really annoying.
Message 28 of 32
jaredhug
Community Visitor
Community Visitor
Auto desk please fix this im using a macbook air 2020 M1 chip, same issue as all above  i have my  macs general trackpad setting set to 2 below the max as above that is way to sensitive for general use. Scrolling up down and sideways is fine in every other app like photoshop or on canva etc, its just fusion 360 where the scroll speed is way to slow having to do multiple full passes of the trackpad to move across the plane a small amount
Message 29 of 32
Phil.E
The newest Fusion build has improvements in trackpad panning. I'd like to hear your feedback about it.
(To get the latest build, 2602.0.71, Help menu > Check for updates)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 30 of 32
nkburdick
Hi @Phil.E,
I'm finding that at least for me, panning and trackpad is working great now!  Thanks for all the hard work!
Nick
Message 31 of 32
Phil.E
Great to hear! Thanks for responding.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 32 of 32
patrickcavanbrown
Mine still gets stuck in slow mode on occasion, but a re-home fixes it.
