Over-constrained error on construction circle
SGoldthwaite
Message 1 of 8
SGoldthwaite
When I try to dimension an construction circle I get an over-constrained error. But I can change the diameter with my mouse.  So it shouldn't be over-constrained.
The sketch was originally created by importing a DXF file.
I made a screencast and attached the Fusion and dxf files.
Screencast: http://autode.sk/1qTjN5V
Replies (7)
Message 2 of 8
promm
@SGoldthwaite,
I am assuming that you have the constrain status preview on.  We are working very hard at solving some bugs that still exists and will be taking the constrain feedback out of preview soon.  I will pass your example along to the development team.  In the mean time try turning the preview off, this should allow you to complete your design.
Cheers,
Mike Prom
Message 3 of 8
HughesTooling
I downloaded the file in the first post and with the constrain status preview off you still get an over-constrained error.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
HughesTooling
Just noticed something odd, there are 2 construction lines that are green meaning they are Fixed they are collinear from the centre of the circle to a point on the circle so should stop you from dragging the circle to a different size.
Mark
Mark Hughes
Message 5 of 8
bmxjeff
Any circle with a tendencies will give the Over constraint error. It's been around a while.
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
Message 6 of 8
n.ebner
Hello!
I have sketch consisting of construction lines, which i can modify with parameters, from which i offset my sketch lines to extrude the body. I experiance the same problem with an overconstrained error message despite some lines are obviously not fully constrained as i can move them.
Is this still a bug or am i doing something wrong?
Kind regards!
Message 7 of 8
TrippyLighting
Please create a new thread and share your design.
Message 8 of 8
n.ebner
