Over-constrain mesasge on partial defined sketch
n.ebner
Message 1 of 8
n.ebner
Hello!
I have sketch consisting of construction lines, which i can modify with parameters, from which i offset my sketch lines to extrude the body. I experiance the same problem with an overconstrained error message despite some lines are obviously not fully constrained as i can move them.
Is this still a bug or am i doing something wrong?
Kind regards!
Attached are the component with the sketch and a screencast.
Replies (7)
Message 2 of 8
neljoshua
@n.ebner,
Definitely a bug; I have seen it too.  I am not able to easily replicate it, though.
My workaround is to delete constraints and dimensions until I am able to get it to work.  Sometimes I have to start all over.  It seems that the order in which constraints and dimensions are applied has an effect.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Message 3 of 8
HughesTooling
I notice you have several offsets in your sketch. One thing to be aware of is you can not dimension an offset curve and have it drive the original. It's a bit difficult to see how you've built that line in the sketch but it might an offset that's the problem.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
n.ebner
Hi Mark, thanks for your reply!
I'm aware of the fact that I cannot dimension the offset generated line to drive the original. The error pops up when I try to dimension the original construction line. But I can move it around by dragging it with the mouse. In the screen cast I'm dragging the construction line and the offset follows accordingly.
Message 5 of 8
n.ebner
Hey Josh!
I experienced the same that, when deleting certain constraints or dimensions I can get some dimensions, that made problems before to work. But at some point you have to place a dimension to finish the sketch, and then it is really frustrating when you get this over constraint message...
Norbert
Message 6 of 8
Oddly enough, if you delete the offset curves and lines and recreate it everything seems to work as expected. Can you confirm that as well?
Message 7 of 8
masa.minohara
Hi all,
I'm sorry about the issue! I tested this and I believe it is a bug. I have logged it as a defect (FUS-30203) and the development team will review and plan for a fix.
Thank you for reporting the issue!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 8 of 8
n.ebner
@Anonymous
Hey!
Thanks for your reply...
Back from weekend, I've now reproduced the behaviour you described. I deleted all offset-lines and lo and behold, I could dimension the sketch without getting the over-constraint error.
Unfortunately my F360 was updated today, so I have to check the change notes if any bug has already been eliminated in the current version.
