Origin position
Origin position
Felipe.G
Message 1 of 15
Origin position
Felipe.G
Hi, I have imported an STEP file, I oriented the file so it imports matching the Origin and orientation of Fusion 360, and looks fine and the orientation looks ok , but when i create a component it creates the conponent with the Origin "off center", any help will be apprciated on how and why is happening and how to fix it
Thnak you for the help
Replies (14)
Message 2 of 15
TrippyLighting
I would be helpful If you created a screencast and perhaps also share the file.
Message 3 of 15
mike.tessier
Hi @Felipe.G,
If you could post an image or an Autodesk Screencast showing the issue, I would be more than happy to help!
Cheers,
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 4 of 15
Felipe.G
Thank you all, I'm trying to get the screencast need to figure it out how that works, but will try soon to have it here
Message 5 of 15
Felipe.G
I added a few pictures hope this can help
Message 6 of 15
mike.tessier
Hi @Felipe.G,
I think I may know how to solve your issue, but could you post an Autodesk Screencast, detailing your workflow from the importing of the STEP file to the creation of the sketch in your pictures? I just want to make sure that the advice I give will get you exactly what you need.
Mike Tessier
Message 7 of 15
Felipe.G
Message 8 of 15
Felipe.G
Got the screencast, you can see if i use an inclined plane to put an sketch on it, the sketch origin is off center from the World Origin, I'm trying to work in a boat and need all parts basically to be referenced to the same origin.
Thank you
Message 9 of 15
Felipe.G
I did this without using the step file and i was able to re-create the same situation, basically working in an angled plane for some reason moves the Origin of the sketch off center
Message 10 of 15
mike.tessier
Hi @Felipe.G,
I was able to reproduce this behavior and I have logged a defect with the development team, as this does not appear to be intended behavior. The reference number is FUS-25516.
For now, to get you back on track, you could try projecting the origin into the sketch you are working on and use that to sketch/constrain/dimension your design accordingly.
Hope this helps!
Cheers,
Mike Tessier
Message 11 of 15
Felipe.G
Thank you Mike, hope gets resolved soon, I'm slowly moving to Fusion for my models and this is a big bug on my design process, thank you for the help
Message 12 of 15
junyuan.zhuJ4HVC
Hi Felipe,
Sorry to hear that this behavior has caused you some trouble.
Currently a new sketch on a work plane will set the origin of sketch to the center of work plane, there are two separate coordinate system for the 3D environment and sketch. Some users want current behavior especially when the work plane is far from the world origin or the new sketch is not related to it. I can understand your need and we will review and discuss on this.
Here's a work-around may be working for now, since creating a sketch on a face will keep the sketch origin the same as the world origin, so just create a new box on the work plane and create a new sketch on the box's face. Delete the box if you are not using timeline(history capture), otherwise it will give you warnings and cause you trouble when you try to edit history later.
Thank you,
Sty
Message 13 of 15
Felipe.G
Thank you, but need the history, i had to go back to my other MCAD software to do this for now, thank you all for the help and looking fwd to the option of an absolute world origin
Message 14 of 15
Felipe.G
Hi, is there any Idea on the progress on when this is going to be fixed?, Thanks!
Message 15 of 15
Exactly same problem as Filipe.G (original poster).  STEP file was positioned at world coordinate 0,0,0 as verified by other cad systems yet have this phantom origin turning up and can't get rid of it.
David
