Opening a file from Autocad to Fusion 360 increases model measurements
Message 1 of 9
I would like to ask some help on, Why is it that anytime I open .dwg .sat .igs . iges files from AutoCAD to Fusion 360 the measurements INCREASE or changes.
What setting or techniques should I use? (I have attached some images with measurements)
Please Help.
17 x 13 mm17 x 13 mm447 x 311 mm447 x 311 mm
Accepted solutions (3)
Replies (8)
Message 2 of 9
lichtzeichenanlage
17.6341in = 447.906514mm. Looks like you're just have to change the document settings in Fusion.
Message 3 of 9
HughesTooling
In AutoCAD you need to set the document units to mm, not sure how that's done now, not used AutoCAD for years. @TheCADWhisperer has helped on this in the past.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 9
lichtzeichenanlage
@HughesTooling: Just a thought: Wouldn't it also help to switch the document units in Fusion 360 after the import?
Message 5 of 9
HughesTooling
@lichtzeichenanlage If you look at th OPs first image it is in mm in AutoCAD and when opened in Fusion it's scaled up by 25.4mm so setting the document in AutoCAD or scaling down in Fusion are the only real options.
Mark
EDIT Actually Fusion normally assumes unitless drawing are in CM so I wouldn't be surprised if @Anonymous has his document set to inches in AutoCAD.
Mark Hughes
Message 6 of 9
lichtzeichenanlage
Okay - I missed to descriptions below the images. I thought just the dimension weren't shown. It's just not my weather right now 😉
Message 7 of 9
TheCADWhisperer
What does the ~dwgunits command report in AutoCAD?
Message 8 of 9
TheCADWhisperer
Oops, that should have been -dwgunits (with the preceding - sign).
Sorry, I was responding from tiny iPad earlier and hit wrong button.
AutoCAD UnitsAutoCAD Units
Message 9 of 9
Thank you. I believe I need more familiarity in import setup for Fusion 360.
