opening a f3z file
opening a f3z file
Message 1 of 38
opening a f3z file
I had downloaded an f3z file but i cant open it in autodesk fusion 360. please help
Replies (37)
Message 21 of 38
ian.byrne
On a mac - High Sierra - I had to add the extension .f3z to the file in Finder before it would work correctly in the data panel.
As downloaded it would fail to unpack and though it uploaded, I couldn't get any options to work with it within the program, with the file extension added it worked exactly as it should, i.e. expanded into components and let me open or insert into design
That was with a file from the myhub.autodesk360.com site
Message 22 of 38
TrippyLighting
What exactly do you mean with "work correctly" ?
I've been working with Fusion 360 for several years and never had any  problems uploading .f3z files or working with them "correctly".
The correct way is yo upload them through the data panel as described earlier in this thread.
Message 23 of 38
rogercaplan
What's the name of the file when it's downloaded (before you manually add the .f3z extension)?
this all works fine for me on High Sierra btw, so I suspect this is an issue with your browser or email client.
Message 24 of 38
ian.byrne
I'm using Firefox 61.0
It definitely comes in without an extension on my system.
link from email...
Get info shows there is no file extension....
Uploaded into data panel...
Doesn't display correctly...
Message 25 of 38
rogercaplan
try renaming the file (in the myhub.autodesk360.com data panel) so it has no spaces in it...
Message 26 of 38
ian.byrne
vs
extension manually added....
Screen Shot 2018-07-05 at 21.44.45.pngScreen Shot 2018-07-05 at 21.45.25.png
Message 27 of 38
ian.byrne
Seems it is just a Firefox problem as with Chrome it comes with the correct extension and behaves exactly as it should, so pretty random and can probably be removed unless you think it will help someone else.
Cheers
Message 28 of 38
rogercaplan
I think this is actually a bug with the myhub.autodesk360.com file download functionality; the "Content-Disposition" http header it's returning does not properly quote the file name.
For example, when requesting a file named "foo bar.f3z", it returns:
Content-Disposition: attachment;filename=foo bar.f3z
when it should return (according to https://www.w3.org/Protocols/rfc2616/rfc2616-sec19.html#sec19.5.1😞
Content-Disposition: attachment;filename="foo bar.f3z"
Message 29 of 38
TrippyLighting
@James.Youmatz could you look into that last post before mine and relate that to the team that AD that deals with this ?
Message 30 of 38
James.Youmatz
Autodesk Support
Autodesk Support
HI @TrippyLighting,
Thanks for the tag, as always! Yea, I've seen this before with the downloads and I vaguely remember it being a firefox specific issue.
Let me bring this up to the team to investigate.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 31 of 38
rsz90182
Community Visitor
Community Visitor
I did exactly this and the file F3Z file uploaded fine.
@HughesTooling wrote:
After selecting the fz3 file and clicking Upload you should see a dialog box like this, there's also a progress meter at the bottom of the data panel.
Mark
Message 32 of 38
liamrcresswell19
Observer
Observer
I am having The exact same issue..... and have no idea how to resolve it.
Message 33 of 38
TheCADWhisperer
Can you Attach your *.f3z File here?
Message 34 of 38
liamrcresswell19
Observer
Observer
 here
Message 35 of 38
TheCADWhisperer
@liamrcresswell19 wrote:
 here
Where?
Do you see it attached here?
You must use the web browser interface to Attach, not email.
You might need to zip the file first and then Attach the *.zip file.
Message 36 of 38
rhetths
Yesterday i saved some files and they saved as f3z which i did not choose and has never happenned before.  Now i cant open them from my computer.
Message 37 of 38
rhetths
Actually it just opened, but it took a million years, massive productivity hit.  When it saved it didn't seem like i had the choice to save it as a f3d file.  I just looked again and i cannot save it as a f3d, why not?  When are they going to stop wrecking the program?  It is like being connected to a mental asylum.
Message 38 of 38
TheCADWhisperer
@rhetths
You have an external reference.
*.f3z file should first be uploaded in the data panel before opening.
