Im pretty new to Fusion 360.
I cant figure out why my sketch profile will not close. I have used the check sketch addon and then manually used the coincide constraint on each open point without any luck. This is from an imported SVG I created from illustrator.
I have linked the file below for you to check if you wish. The problem area is the golf ball on the tee, the highlighted line in the ball.
Any help would be appreciated!
Thanks!
Hmmm, seems if I max out the corners on the image trace options in illustrator and reimport the svg the problem disappears.
